А на какую версию IOS обновить?
Вот Show ver
ts-c7206#sh ver
Cisco IOS Software, 7200 Software (C7200-IS-M), Version 12.4(19), RELEASE SOFTW
RE (fc1)
Technical Support:
http://www.cisco.com/techsupportCopyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 01-Mar-08 04:41 by prod_rel_team
ROM: System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVE
OPMENT SOFTWARE
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.1(5)T12, RELEASE SOFTWARE (
c1)
ts-c7206 uptime is 13 hours, 54 minutes
System returned to ROM by error - an Error Interrupt, PC 0x607FB2C0 at 12:51:12
MSD Tue Oct 24 2000
System restarted at 01:02:55 MSK Thu Feb 12 2009
System image file is "disk1:c7200-is-mz.124-19.bin"
Cisco 7206VXR (NPE400) processor (revision A) with 491520K/32768K bytes of memo
y.
Processor board ID 36320514
R7000 CPU at 350MHz, Implementation 39, Rev 3.2, 256KB L2 Cache
6 slot VXR midplane, Version 2.11
Last reset from watchdog reset
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb0_mb1 has a total of 400 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4, 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
2 FastEthernet interfaces
125K bytes of NVRAM.
47040K bytes of ATA PCMCIA card at slot 1 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2102
