Может выжимку приведете (краткие характеристики), что есть и тогда попадает под WiMaxAlexSH писал(а):Да и вообще в 6 ГГц это не WiMAX!!!
The terms "WiMAX", "mobile WiMAX", "802.16d" and "802.16e" are frequently used incorrectlyCorrect definitions are the following:
802.16-2004 is often called 802.16d, since that was the working party that developed the standard. It is also frequently referred to as "fixed WiMAX" since it has no support for mobility.
802.16e-2005 is an amendment to 802.16-2004 and is often referred to in shortened form as 802.16e. It introduced support for mobility, among other things and is therefore also known as "mobile WiMAX".
Working group history
IEEE 802.16 standardizes the air interface and related functions associated with wireless local loop. The charter originally envisioned that three working groups would each to produce a stand alone standard referred to as 802.16.1, 802.16.2 and 802.16.3. During development a decision was made the first and third tasks were significantly related; the result was two standards and an amendment were released.
IEEE 802.16 (formerly 802.16.1) - Air interface for 10 to 66 GHz,[2] also known as Local Multipoint Distribution Service. It was approved in December 2001. It delivered a standard for point to multipoint Broadband Wireless transmission in the 10-66 GHz band, with only a line-of-sight (LOS) capability. It uses a single carrier (SC) physical (PHY) standard.
IEEE 802.16.2 - Coexistence of broadband wireless access systems.[3]
IEEE 802.16a (the former 802.16.3) was an amendment to 802.16 and delivered a point to multipoint capability in the 2-11 GHz band. For this to be of use, it also required a non-line-of-sight (NLOS) capability, and the PHY standard was therefore extended to include Orthogonal Frequency Division Multiplex (OFDM) and Orthogonal Frequency Division Multiple Access (OFDMA). 802.16a was ratified in January 2003 and was intended to provide "last mile" fixed broadband access.
802.16c, a further amendment to 802.16, delivered a system profile for the 10-66 GHz 802.16 standard.
In September 2003, a revision project called 802.16d commenced aiming to align the standard with aspects of the European Telecommunications Standards Institute (ETSI) HIPERMAN standard as well as lay down conformance and test specifications. This project concluded in 2004 with the release of 802.16-2004 which superseded the earlier 802.16 documents, including the a & c amendments.
An amendment to 802.16-2004, IEEE 802.16e-2005 (formerly known as IEEE 802.16e), addressing mobility, was concluded in 2005. This implemented a number of enhancements to 802.16-2004, including better support for Quality of Service and the use of Scalable OFDMA, and is sometimes called “Mobile WiMAX”, after the WiMAX forum for interoperability.
Мы соединяем свои локальные сети. Дальности от 4 до 25 км.
AlexSH писал(а):Про Микран наверно реклама?
AlexSH писал(а):можно подцепить их т.н. множественной точкой-точкой.
AlexSH писал(а):Да и вообще в 6 ГГц это не WiMAX!!! Короче все сообщения в теме - это оффтоп. Надо поменять тему может быть. Или вообще закрыт.
AlexSH писал(а):Про Микран наверно реклама? Я на сколько знаю, они серийно не производят в 6.4
Связной (С) писал(а):Может выжимку приведете (краткие характеристики), что есть и тогда попадает под WiMax
OKT писал(а):Производят, http://www.micran.ru/productions/teleco ... /wireless/
Железяка полнофункциональная, знаю где эксплутируется.
...оборудование которое еще должно пройти сертификацию WiMAX Forum.AlexSH писал(а):Некоторые производители делают решения
AlexSH писал(а):мне люди из Томска заявляли, что образцы есть, но серийно не выпускается. Если кто знает точнее, прошу поделиться информацией.
Чем сплети слушать возьмите да попробуйте, можем посодействовать :) поставка - пару недель
Semen_Andreev писал(а):что-то не верю что микран может сроки поставки меньше месяца выдержать
OKT писал(а):Чем сплети слушать возьмите да попробуйте, можем посодействовать :) поставка - пару недель
OKT писал(а):до конца года конультации по микрану даю бесплатно, потом - банку пива за каждую
AlexSH писал(а):Если есть аргументация, приведите, если нет, то можно любое заявление на форуме считать сплетнями.
Erlang писал(а):Вы это - аккуратнее - так и Микран разорим.
Erlang писал(а):+1
Народ с просьбой помощи обратился.
