Hicom 300 - HISTA
Rapport
25 сен 2007
Мурманск
Hicom 300 - HISTA
СообщениеRapport » Вт 25 сен, 2007 11:54 »
Здравствуйте.
Вопрос по станции Hicom 300.
Нет ли у кого-нибудь доки с расшифровками кодов сообщений HISTA (ну например F2202, F6248 и пр.)?
Или подскажите что означают вот эти:
F1010 E8 N0781 NOTICE SIT TOP PABX 600 07-09-24 23:14:50
ALARM CLASS:CENTRAL:024
FORMAT:--
F2102 E8 N0782 NO ACT A1 IX UNIX MESSAGE 07-09-24 23:14:50
ALARM CLASS:CENTRAL:027
UNIX NAME: UNIX TIME:-------- --:--:-- RESTART COUNT:0
-- :-- :-- :000: -- -- BST:-- FW: --
FORMAT:3A
IX-TASK: UNIX mem sufficient Avail. RAM: 58171141 Byte
Required minimum: 25 MB
F6506 E8 N0783 RELOAD A1 SM-DEP RESTART LEVEL 07-09-24 23:14:50
ALARM CLASS:CENTRAL:010
RESTART TYPES: RELOAD
FORMAT:41
F6266 M8 N0784 NO ACT A1 SM-DEP ADVISORY 07-09-24 23:14:50
ALARM CLASS:CENTRAL:023
FORMAT:C
*** MESSAGE ***
CURRENT LOAD DEVICE IS HD
F6266 M8 N0785 NO ACT A1 SM-DEP ADVISORY 07-09-24 23:14:50
FORMAT:17
RELOADED SUBSYSTEMS:
:PDS:APSZ/ISU/BS/ABS/ZDAADS00
F2201 M8 N0786 NO ACT A1 PROC INT STACK 07-09-24 23:14:29
CC:00000 EC:00000 UA:BDBC:0EBA SP:9A68:1FD8 BP:1FD8 LD:01-00-255-000
FORMAT:45 MESSAGE-ID: 01502
STACK-DATA-MESSAGE 01 OF 01
---8---A ---C---E ---0---2 ---4---6 ---8---A ---C---E ---0---2 ---4---6
1FF20724 00BE0FFE BE1C006C 0461BDC4 5A5A001B 325D00E3 00150000 008899B0
FFFF9A70 041BBE1C
F2203 E8 N0787 NO ACT A1 PROC INT TASK ADDRESS 07-09-24 23:14:29
FORMAT:17 MESSAGE-ID: 01502
TASKADDRESS BE1C:041B
F2218 E8 N0788 SOFTREST A1 PROC INT GENERAL PROTECTION 07-09-24 23:14:29
INTERRUPT:0D AX:BDE5 BX:10C3 CX:0000 DX:0C08 BP:1FD8 SI:006C DI:0302
CS:BDBC IP:0EBA CSLIM:0FA9 CSAR:9B SS:9A68 SP:1FD8 SSLIM:1FFF SSAR:93
DS:BDC4 DSLIM:085F DSAR:93 ES:BDC4 ESLIM:085F ESAR:93 NMI REG:0000
FORMAT:2B MESSAGE-ID: 01502
A9008 M8 N0789 NO ACT A1 NMCALARM MIRROR: CENTRAL GRP 07-09-24 23:14:50
DEVICE ALARM: 00000000
MINOR ALARM: 00000000
MAJOR ALARM: 00000000
FORMAT:30
A9011 M8 N0790 NO ACT A1 NMCALARM MIRROR: SMPER GRP 07-09-24 23:14:50
MINOR ALARM: 000000
MAJOR ALARM: 000000
FORMAT:30
F8267 M4 N0791 NO ACT BPA TRANSSYS ON CONN OS NEW 07-09-24 23:14:50
PARTNER:A1 IP-ADDR:192.0.2.3 TCP-PORT:0
LOCAL: IP-ADDR:192.0.2.1 TCP-PORT:0
P102: :CC A :000: Q2270-X DPC5 BST:08 FW: D971-D
FORMAT:3C
SUB-MSG-NO:1
F8267 M4 N0792 NO ACT A1 TRANSSYS ON CONN OS NEW 07-09-24 23:14:56
PARTNER:BPA IP-ADDR:192.0.2.1 TCP-PORT:0
LOCAL: IP-ADDR:192.0.2.3 TCP-PORT:0
** : :A1 B :046: Q2270-X DPC5 BST:08 FW: D971-D
FORMAT:3C
SUB-MSG-NO:1
F2102 E8 N0793 NO ACT A1 IX UNIX MESSAGE 07-09-24 23:14:56
FORMAT:3A
LD-TASK: IX-BIOS initialized
F2102 E8 N0794 NO ACT A1 IX UNIX MESSAGE 07-09-24 23:14:56
FORMAT:3A
LD-TASK: IX-BIOS started
F5130 E8 N0795 NO ACT BPA SM/UNIT ON-LINE 07-09-24 23:14:55
ALARM CLASS:CENTRAL:026
SLOT TYPE:DP-SM ERROR LOCATION:A1
FORMAT:29
F7662 E8 N0796 NO ACT A1 LCX-CHAN DONGLE ATTACHED 07-09-24 23:14:57
ALARM CLASS:SM-PER: 000
CHAN NO:08 CHAN TYPE:NO MODEM CHAN SI:TELETYPE
FORMAT:10
181AFFFFFFFF08FFFFFF000000000030 00000000000000000000000000000000
000000005A5A5A5A5A5A5A5A5A5A5A5A 5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A
5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A 5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A
5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A 5A5A5A5A5A5A5A5A5A5A5A5A5A5ACE00
00
F7628 E8 N0797 CHAN OOS A1 LCX-CHAN LCU CONTROL LINE ERROR 07-09-24 23:14:57
FORMAT:10
091AFFFFFFFF08FFFFFF000000000300 00000000000000000000000000000000
FFFFFFFF5A5A5A5A5A5A5A5A5A5A5A5A 5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A
5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A 5A5A5A5A5A5A5A010801010202020202
42
F7628 E8 N0798 CHAN OOS A1 LCX-CHAN LCU CONTROL LINE ERROR 07-09-24 23:15:00
CHAN NO:09 CHAN TYPE:NO MODEM CHAN SI:TELETYPE
FORMAT:10
091AFFFFFFFF09FFFFFF000000000300 00000000000000000000000000000000
5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A 5A5A5A5A5A5A5A010808010202020202
42
F2102 E8 N0799 NO ACT A1 IX UNIX MESSAGE 07-09-24 23:15:20
FORMAT:3A
LD-TASK: BOOT system loaded and started
F2102 E8 N0800 NO ACT A1 IX UNIX MESSAGE 07-09-24 23:15:34
FORMAT:3A
CT-TASK: BOOT system running
F2105 E8 N0801 NO ACT A1 IX UNIX FATAL ERROR 07-09-24 23:15:35
FORMAT:3A
Unix Base installation failed too many times
F2102 E8 N0802 NO ACT A1 IX UNIX MESSAGE 07-09-24 23:15:36
FORMAT:3A
Starting Boot-Unix interactive menu
A9001 M5 N0803 NO ACT A1 NMCALARM MAJOR ALARM ON 07-09-24 23:15:42
ALARM NAME:UNIX FAILURE
FORMAT:2C
A9000 M5 N0804 NO ACT A1 NMCALARM MINOR ALARM ON 07-09-24 23:15:50
ALARM NAME:IS RESTARTS
FORMAT:2C
isberg
27 янв 2006
Сообщениеisberg » Вт 25 сен, 2007 13:37 »
Сюда не ходили?
http://www.ics-hicom.ru/
Rapport
25 сен 2007
Мурманск
СообщениеRapport » Вт 25 сен, 2007 14:53 »
Сходил.
Документация в целом у меня есть. Нет именно расшифровок кодов ошибок.
